Poll: What is the software you use to frameserve?
Be advised that this is a public poll: other users can see the choice(s) you selected.
    May 2002
    Brazil
    Hello everyone.
    I'm Brazilian and most of movies I get on the Internet are in english (also dubbed).
    Because of this, I always put the subtitles im my language in a VCD (not SVcd, but please dont let start a battle of formats, ok? - I get some reasons to make this type of encoding anyway) with the movie.
    I always use PERMANENT subtitles, so I frameserve all times.
    I use virtualdub to frameserve and put the subs in the movie.
    But it is really slooow...
    So I want to try some diferents ways to get some speed.
    I had tried some frameserve with AviSynth (only the movie, without subs) and I realize that frameserve with AviSynth is Faster (sometimes 2,5x faster), but i cant make it frameserve my subtitle with the movie.
    I Always get some kind of error, whatever i try.
    For example, look this script that I modify using some directions on the www.avisynth.org:
    AviSource("c:\film\film.avi")
    BicubicResize(320,126,0,0.6,54,0,531,272)
    This works (frameserve to CCE) and also I can open it in WMP.
    When I modify it to make it include the Sub:
    LoadPlugin("c:\virtualdub\textsub.vdf")
    TextSub("c:\film\film.sub")
    As you can see in the code, I'm using TextSub from VOBSub package. It Works well in Vdub, so I imagine that the plugin is OK.
    When I Open in WMP i get a error.
    When I try to encode in CCE, it freeze.
    I Also tried to change de script, because of a recomendation in AviSynth.org to use the filter "DirectShowSource()", and it also dont works.
    If any of you know how to make this, please post here. put some examples...
    I will be very gratefull.
    'cya
    May 2002
    Brazil
    Well my friends...
    Because nobody puts any question or solution here, I had tried many others times...
    So I finally get it to work...
    Some words...
    "Ever put the FULL PATH to every file..."
    Never forget that. I will not. No more...
    Cya
    Upstate NY
    Also for avisynth I have found 2 things are important...
    1) Get an updates copy from www.avisynth.org
    2) Be sure you are feeding filters what they want ( RGB OR YUYV soon YV12 )
    May 2002
    Brazil
    Snowmoon, how do I detect witch filter to use?
    I imagine that I must look in the source file? Or the filters apply to the destination file?
    thanks for posting.
