Results 1 to 11 of 11
  1. Does anyone know how to pass the 30 day limit on SVCD encode ?
    What do I need to do to reset the limit?
  2. The 30 day limit can be reset by deleting the following registry key:
    HKEY_CLASSES_ROOT\CLSID\{63902277-B101-4049-8B46-C24B67E155E5}
    Or, make a file "TMPGEnc_MPEG2_Reset.reg" with the following content:
    REGEDIT4
    ; Enables TMPGEnc's MPEG-2 encoder for 30 more days.
    [-HKEY_CLASSES_ROOT\CLSID\{63902277-B101-4049-8B46-C24B67E155E5}]
    Double click this file to reset the 30 day limit. Truman, I know this gets asked all the time but the newbies don't know that
  3. Could anyone give any insight on "how to" find this Registry Key to delete it??
    e-mail me at- hp8555@bellsouth.net
    Thanks in advance,
    hp
    Jul 2001
    Maryland
    if you do this, you'll be fine.
    tmpg uses your system clock.
    delete tmpg directoy and all files.
    download a new copy.
    set system clock -the one on the tray- to a far off year, perhaps 2020.
    run tmpg.
    close tmpg
    return your clock to the present.
    you mpeg 2 should last until until 2020.
  5. Cheers guys.
    Big help there.
    Jul 2001
    lancashire
    Does this work with other trial software ? I have got power director and thats only a 30 day trial version. ?
  7. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    Probably. If you knew the registry entry.
  8. <TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR size=1 color=black></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
    Simply put, no.
    Jul 2001
    Maryland
    i always wondered how things like demos know u installed them before.
    i removed the reg entries n everything.
    Jul 2001
    lancashire
    Sh-i-t if only I had a reg key or somethin' !!! Life would be better !!!
