My usb connection to my sony digital video camera seems to capture ok. If I get a firewire card (dv in\out) can I expect any difference in the captured video?
Are you able to capture without compression and without any frames dropped? You can with Firewire.
Firewire is capable of copying the video directly without further compression (DV is 1:5 compression -- I'm assuming you mean a DV camera) and will give you the best quality. I don't know the format you're getting with usb, but usb 1.1 can only transfer 1.5MB/s so you'll either have an mpeg or a low bitrate avi, and either way it's probably much lower resolution.
Thorn, banjazzer, thanks for your replies. It did seem like the mpeg image was a little choppy. I'll get the firewire card asap.
Firewire to USB ?
By vhelp in forum ComputerReplies: 5Last Post: 11th Aug 2011, 22:03 -
Question about USB to Firewire?
By Lucid_Dream in forum ComputerReplies: 1Last Post: 4th Jan 2011, 12:37 -
Firewire to usb 2.0 cable
By zanos in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 1st Aug 2010, 13:28 -
USB or firewire
By rjack in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2009, 22:42 -
Firewire to USB
By DNCR556 in forum Newbie / General discussionsReplies: 3Last Post: 24th Nov 2007, 11:45
