I just bought DV-Wizard from Hauppauge. It includes Ulead VideoStudio 5.0 SE.
When I tried to capture video to my computer using my Sony Digital8 DCR-TRV310 NTSC with Hi8 tapes. Everything seems to work ok upto now..
until attempting to make VCD (using Nero 5.5) so I can play it on my AWA DVD Player (Multi-region/zone). The VCD fails to work on my DVD player, when the disc is attempting to load, I could hear the clicking/ticking/skipping sound coming from the DVD player, after couple of minutes, the message display that "no disc is found" or loaded but yet the disc is still in the player.
Note: i'm able to play this VCD on my computer using PowerDVD.
Please advice what I should do.
Thanks alot.
Albert
Don't author your VCD's with Nero! It seems that many stand alone players have problems with Nero manufactured VCD's, at least if menues are used. Try VCDEasy instead.
/Mats -
It's probably not Nero's fault. He/She probably didn't use the correct template, or they didn't use a template at all, attempting to make a data CD as a Video CD. Make sure you use the latest version of Nero, and select the correct template and type for your player (NTSC/PAL, and Video CD). Nero will warn you if your MPEG is non-standard this way.
Impossible to see the future is. The Dark Side clouds everything...
Weird Problem - Adding subs to avi doesn't work okey on DVD Player
By andreas.cro in forum Newbie / General discussionsReplies: 6Last Post: 1st Aug 2012, 12:29 -
Please help! New DVD player doesn't work :(
By confuzedinTN in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Sep 2010, 13:44 -
Video from PC encoded and Burnt to VCD to Play on my DVD R Player
By dashas in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 21:15 -
Playback Error on DVD player..... Process used to work now it doesn't!
By Sisi in forum Authoring (DVD)Replies: 3Last Post: 23rd Feb 2009, 13:07 -
region 2 dvd doesn't work with media player classic
By clamchowder01 in forum Software PlayingReplies: 5Last Post: 17th Oct 2008, 22:27
