Can anyone help with this
I ve got a DIVX copy of Episode 2 which appears to be perfect
However when I try to convert using TMGEnc the picture disappears after 50 minutes and doesn't come back - its just a black screen although the sound continues to play
I've tried a couple of times but the picture always goes off at the same point
Any ideas ? I've never seen or heard of this happening
If you get an error message when opening the video or audio like file unsupported
or you get an empty(black) video preview window
or the video look wierd in the video preview window like green or purple or pink
Be sure that you have installed the DivX Codecs (both DivX 3.11, 4 and 5) and also try with the Nimo Codec Pack. If that does not work try to change the codec reader settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 and try open the video.Hello. -
Thanks for that I'll try altering the TMGEnc settings
The problem doesn't appear to be codec related as the DIVX plays fine all the way through and the resulting MPeg is fine all the way through until the 50th minute when it turns into a black screen , not a preview screen , but the actual screen using my external DVD player and Power DVD 4 both turn black
Question about valuable part in neck of picture tube
By jimdagys in forum Newbie / General discussionsReplies: 15Last Post: 1st Dec 2010, 07:11 -
Missing video part in .avi file
By CoMuNisTa in forum Newbie / General discussionsReplies: 8Last Post: 21st Jun 2010, 13:08 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 15:32 -
icons missing picture
By jyeh74 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2009, 16:48 -
Extract part of picture while keeping right aspect ratio
By cd090580 in forum Video ConversionReplies: 12Last Post: 6th Oct 2008, 06:04
