I've found several guides explaining how to get the best out of CCE, but most of them are for NTSC. Does anyone know the best settings to re-encode a 4:3 PAL DVD? I think I should use the following, but could someone correct me if I'm wrong!?
MPEG-2 Video Settings
Add sequence end code
Linear Quantizer Scale
Zigzag scanning order
DVD Compliant
Luminance Level: 16 to 235
Timecode 00:00:00:00
Also in the GOP menu, I change settings to M=3 N/M=4. I also change the image quality priority to 5.
I presume I don't need to check "Progressive frames" as the source is PAL.
Thanks for youe help!
The only check boxes I use for PAL are:
Upper field first
DVD compliant
Luminance level 16 to 235
Timecode 01:00:00:00
In the GOP menu the correct settings for PAL are M=3, N/M=5
Check CRC should be enabled in the Audio menu.
In version 2.64 the natural state of the encoder is upper field first, and checking the upper field first box toggles the state to lower field first which is required for PAL (this is the exact opposite of version 2.50).
The timecode 00:00:00:00 has a special function according to Cinemacraft and should not be used.
Hope this helps you, regards. -
Originally Posted by King Dick
you SHOULD use the timecode 00:00:00:00 or you could have problems later with authoring programs!
you SHOULD use Bitrate Viewer to see what options you need to check in CCE and what you dont need to check.
Zzzzzzzzz -
I have more often than not heard the fact that time code ( all 0's ) is not the best to use and that other ( 1, all 0's ) is better.
By far the best quality can be achieved, just make sure to reduce the setting qualiy/image complxity to 5-10. -
CCE doesn't know if you are trying to encode interlaced PAL or 24fps video sped up to 25fps. I suggest that you check PROGRESSIVE FRAMES.
I've also heard of that 01:00:00 timecode thing, but I've always changed my timecodes to 00:00:00 and I don't have any problems (I would really like a decent explanation as to the whysand why not of this timecode with the "1" thing).
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 22:30 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 19:23 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 02:18 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 18:33 -
CCE SP 2.67 Advanced Settings (VBR Bias, Quality Precision)
By seven_deuce offsuit in forum DVD RippingReplies: 3Last Post: 11th Mar 2008, 17:30
