  1. If I convert an MPEG of any kind to VCD using TMPEG, it plays fine on my DVD player.
    But, if I convert a DivX of any kind to VCD using TMPEG, they sutter and lose sync on my DVD player and I have no idea why.
    The odd thing is that if I encode the same DivX to SVCD - then it plays fine.
    I do all the things I am supposed to like using VirutalDub to create a WAV file first and then using that with the video file.
    Any ideas why TMPEG is causing this problem?
    Thanks tons all!
    Gray
    Apr 2002
    The State of Frustration
    Do you use templates?
    Hello.
  3. Yeah Tommy I use the correct templates.
    It seems to only happen when I convert DivX but I don't know why?
