AM HAVING A PROBLEM WITH TMPGENC 2.58 WHEN I LOAD AN AVI FILE IT CRASHES. I TRIED TO INCREASE THE VFAPI-PLUGIN SETTINGS AND IT CRASHES. THIS IS WHAT I HAVE AS MY SETTINGS.
DIRECTSHOW MULTI FILE READER 2
EVERYTHING ELSE 0
AVI VFW COMPATIBILITY READER -2
WHEN I LOAD THE MOVIE IN THE BROWER IT CRASHES
NO ERROR MESSAGE.
PLEASE TELL ME WHAT TO DO.
try extracting the audio and saving it as a WAV using the WAV as the audio source in TMPGE:
http://www.vcdhelp.com/virtualdubaudio.htm
You can also try checking for bad frames using either DivFix or this version of Virtualdub (which is much better)...
Scroll down and download the "mp3_Freeze" version:
http://www.digital-digest.com/dvd/downloads/virtualdub.html
If you find bad frames (and its only up to 2 or 3 hundred.......any more than that and it will be quite noticeable in most movies) then you can extract them with Virtualdub."Today is only yesterdays tomorrow" -
it allows me to load dvd rip movies it's only the internet movies that it does not let me load. only way it works now is with the original settings
avi vfw -2 and the directdraw at -1
but now the movie after encoding comes out with a purple haze.
Problem With TMPGEnc
By Halibut72 in forum Video ConversionReplies: 2Last Post: 1st Oct 2008, 12:38 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 15:38 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 16:58 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 18:56
