    Aug 2002
    Anyone had any luck with ripping something from a DVD-R made with the DMR-HS2? I used smart ripper to extract the .vob files, and tried to load the .vobs into TMPGEnc to make mpeg1 files for VCDs for my friends. It works for about the first 10 seconds, then it stalls. There is also no audio when I try it this way. Anyone else got a better way to do this? Any help would be greatly appreciated! Thanks...
    Drew
    --Drew
    Aug 2002
    No tips huh? Thanks anyway...
    --Drew
