hey guys,
dunno if anyone else has this problem, but when i play my rip of panic room on my dvd player (pioneer dv333), near the very end right after jodie foster is looking directly into the camera and then the scene blacks out and then appears with her and her daughter sitting on the bench in the park, the audio skips during that black transition. this ONLY happens on my dvd player and not on my computer. i've done basically everything....
1) increased my min bitrate to 300, then 500, then 1000
2) IVTC
3) encoded as 29.97 fps + interlaced
4) used external audio encoder (lame)
5) used dvd2avi to quality downsample, instead of tmpgenc
6) used flask instead of dvd2avi
the problem is still there at the exact same spot..i was wondering if any1 else has the sample problem and if there are anything else i can try
yeah. I have that problem too....almost. On mine, instead of a skip the audio drops completely out for about 30 seconds. My standalone is an Apex 1100/w *new 512* I've tried pretty much the same set of fixes as you also and no luck.
Outta sync issues after converting MKV's
By snowseals in forum Video ConversionReplies: 2Last Post: 1st Jan 2012, 05:56 -
not enough room
By agent222 in forum Video ConversionReplies: 3Last Post: 9th Apr 2011, 12:16 -
connect pc to another room monitor
By blader18 in forum Media Center PC / MediaCentersReplies: 2Last Post: 30th Sep 2009, 15:19 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
Chat Room Required
By Ryudo in forum Off topicReplies: 3Last Post: 21st Jun 2007, 08:35
