hello-
i have recently learned (from this site) how to make VCDs, and have encountered only one problem. here it is:
i have 2 DVD players. one is a Mintek 1600, and the other is an AIWA XD-DV370U.
i used TMPGEnc to create an MPEG file from an .ASF/MPG stream i downloaded, then used VCDeasy to burn a single-track VCD with no menus or chapters from just that one file. (all based on the guides at vcdhelp.com)
in the AIWA player, it plays perfectly.
in the Mintek, the picture is very choppy, but the sound is fine.
is this common?
does it have something to do with the TMPGEnc conversion i did?
what can be done?
also, if the AIWA player i have hasn't been listed, it plays VCDs but not SVCDs. I haven't checked it with anything else.
(1) Are you sure that you used the VCD template with TMPGEnc?
If so, then the most likely problem is a media compatibility issue with one of the players.
Regards.Michael Tam
w: Morsels of Evidence -
Originally Posted by johnny-5tuco
Whats a simple software DVD player that just works !
By Bansaw in forum Newbie / General discussionsReplies: 4Last Post: 6th May 2011, 15:20 -
trying to fix a scratched dvd, works on pc but not player...
By extent in forum Authoring (DVD)Replies: 3Last Post: 28th Feb 2010, 09:02 -
Sound works on Pc but not on Dvd player
By Rogert in forum AudioReplies: 4Last Post: 7th Jun 2008, 07:22 -
DVDRW works fine on PC, not on DVD Player
By Koopzer in forum Newbie / General discussionsReplies: 3Last Post: 21st Apr 2008, 02:54 -
my dvd-lo that works on Mac, not in external player
By oldblues in forum ffmpegX general discussionReplies: 8Last Post: 11th Jul 2007, 03:22
