I was using Nero to encode my vbideo and it was coming out upside down and backwards so after searching the forum was told to download and use TMPGenc to encode instead. All my movies are .AVI and when I try to select them to encode it tells me can't open, invalid file. I'm going nuts. Please help.[/b]
Go to Options>Enviromental Settings>choose the VFAPI-plug in tab. Raise your direct show to 2. Do this by clicking on it and then right clicking on it and hit raise priority. Do it until it goes to 2. This will allow you to open AVI files. Hoped this helps. If you dont know how to do this......you gotta along way to go
Black Bar problems with TMPGEnc
By ereiamjh in forum Video ConversionReplies: 5Last Post: 22nd Mar 2010, 11:32 -
TMPGEnc Authoring Works 4 Problems
By DJ_OB1 in forum Newbie / General discussionsReplies: 0Last Post: 1st Aug 2009, 13:20 -
Problems with TMPGEnc...
By SolsBBQ in forum Video ConversionReplies: 5Last Post: 3rd Jan 2009, 07:00 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 19:37 -
By maccool111 in forum ComputerReplies: 3Last Post: 23rd Jul 2007, 17:47
[/b]
