I am having these question/problem:![]()
1. Does PCTV Pro able to captured and burn video in XSVCD mode? I tried to customise the video capturing mode to a lower bitrate but were unable to do so, since its lowest are 2.5 M/bits
2. There is a Video tab in the setting, in the section Video Display given option of 2 fields interlaced, 2 fields deinterlaced and 1 field only, what does this mean? do they affect the video capturing?
3. When I wish to burn a VCD\SVCD with more than 650MB using the PCTV Pro, it always automatically cut my mpeg file into lower than 650MB(mean when it supose to be a 77 mins movie, it cut down to 74 Min at the endding part) even though I select 700MB media
Thanks for reply[/code]
Results 1 to 1 of 1
pinnacle pctv 310i
By marc21782000 in forum Capturing and VCRReplies: 10Last Post: 4th Jan 2010, 02:30 -
Pinnacle PCTV HD Pro Stick, my experience
By vhelp in forum DVB / IPTVReplies: 46Last Post: 14th Oct 2009, 19:36 -
What software for Pinnacle PCTV HD?
By tomreedtoon in forum Capturing and VCRReplies: 10Last Post: 9th May 2009, 06:14 -
Audio problems with Pinnacle PCTV HD Pro Stick.
By cactusjack310 in forum AudioReplies: 0Last Post: 21st Jan 2008, 17:16 -
Which is best, Pinnacle 110i or PCTV Pro PCI
By brvignesh in forum Capturing and VCRReplies: 23Last Post: 28th Nov 2007, 22:40
