Hello I am a newbie to the board but will be returning a lot by the looks of it
I have a problem I shoot my own footage with some friends and am trying to create a DVD to distribute it on
I capture to full quality DV and edit it in studio 7
I now want to create a mpeg compliant mpeg file using either Studio 7 or external encoding software (TMPGEnc Plus)
But after I have converted the video when I play it back it seems to have lines throughout the footage on any moving images
What I need to know is is this because I am viewing the file on my PC and after I have burnt it to DVD it will be fine or is it an encoding error it seems to happen both in Studio and TMPGenc
any ideas?
Thanks in advance
Stern
DV video is interlaced. The motion artifact you are looking at is called "combing". Check this out for an explanation: http://www.lukesvideo.com/
There are a number of ways to reduce interlacing artifacts. Do a search on this site for solutions. The subject has been discussed extensively.
Good Luck! -
cheers fella!
Will check it out and see what I can come up with
Will let you know
Stern
The best MPEG 2 encoding software?
By whatever911 in forum Video ConversionReplies: 20Last Post: 8th Oct 2012, 08:54 -
MPEG encoding for DVD
By BraDave in forum AudioReplies: 4Last Post: 3rd May 2011, 23:34 -
Encoding problems
By cdaters in forum ffmpegX general discussionReplies: 8Last Post: 2nd Feb 2010, 19:27 -
Encoding problems
By El Barto619 in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2009, 22:32 -
Problems encoding!
By villa99 in forum ffmpegX general discussionReplies: 4Last Post: 25th Mar 2009, 12:50
