OK, tonight I decided to test out my video computer. I captured my copy of Scary Movie via DV to my computer(specs should be listed) and then cut it up for a VCD. Captureing and editing went as well as could be expected...no dropped frames, easy cuts, etc... Then, I started to render the video into another DV AVI file...exact same settings as the captured one. .03 FPS! I could understand this more once I begin converting to MPEG, but not just trimming! ANY ideas?
is that Adobe Premiere that u're using?
it did that to me too - it reencodes the file. And i could never figure out what .03 stands for: 'cause it would show that i have 300 frames in a 5min file or so and then calculate the rendering rate from that figure.
So obviously the adobe definition of a frame is different from what we r used to...
i could never figure out how to do just a direct stream copy of a file with Premiere, like vdub does.
hope this helps.
keifir -
you could use a lot more memory ... DV still requires compressing as its a compressed format ..
capture via DV a dvd ?
dont re-encode to avi again if you can help it .. -
Yea, I'm using Premiere... I know what the .03 stands for, but a more suitable speed would be in the 20s or 30s(or 60's as I've gotten on my Athlon) And I know it's actually going slow, as it only got a few seconds of video within several minutes of rendering.
I'll see about more memory, but I figured this should be enought since NOTHING else is running. Well, I have to re-encode to AVI. Premiere(or my copy) dosn't have a why to export to MPEG... SO, I have to re-encode, then use another program to convert to MPEG. And I'm capturing VHS to DV.
Horrible audio synch
By rocks911 in forum Video ConversionReplies: 9Last Post: 13th Jan 2012, 04:50 -
Horrible Bosses is pixelated on my computer
By mowermanEd in forum Newbie / General discussionsReplies: 1Last Post: 12th Nov 2011, 09:35 -
DVD to H.264 - Different Running Times, Chapter Times Wrong
By nrogers64 in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2009, 18:28 -
Subtitles !! work horrible !!!
By philparis in forum ffmpegX general discussionReplies: 6Last Post: 27th Feb 2009, 16:44 -
why is my video quality so horrible?
By crazymonk848 in forum Newbie / General discussionsReplies: 10Last Post: 21st Mar 2008, 13:23
