I have downloaded movies which seem to be in rare format. Can someone please tell me what do I do next to be able to view them on my DVD or pc? Some of the encoding applications are new to me and I cannot understand some of it. I would really appreciate it.
Thanks much!![]()
I suggest that you download the nimo codec pack... after you install it your media player should play just about anything
You can download an identity tool and use it to figure out what codecs you need for your video file...
http://www.headbands.com/gspot/
If it turns out you don't have a codec that's needed, then all you have to do is go download it from a web site.. such as
http://www.digital-digest.com/ -
Ok, I 've learned how to watch then using DivX on my pc.....but I really want to burn them so that I may watch them on my DVD Player.
Can you please help me....I am a willing student.....Thanks.
ok go to tools to your left and dload tmpgenc.
open that
use the vcd or svcd template
browse for the movie and click on it hit next till you come to the screen that asks you where to output
browse for the spoy you want to output to
click next and it will convert
to burn to compliant vcd you need a good burn program use nero, or ulead dvd moviefactory to burn a compliant vcd, or svcd
use the search here to find topics in the past relating to this. research and do the footwork then ask intelligent questions. hope i helped -
Instead of Nero or the other one you listed, can't I just use Roxio Easy CD Creator 5 which is the newest version out. I purchased it not long ago?
And, by the way, thank you.
You could use Easy CD 5 Platinum, but only if you want to go bald (it is VERY buggy).
Follow this guide:
http://www.vcdhelp.com/tmpgenc.htm
to get mpegs of the required length then burn the mpeg with Easy CD 5.
Regards,
Rob
Best way to play Downloaded 3D Movies
By mafioso22 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 12th Feb 2012, 13:22 -
What Program will convert both DVD and Downloaded Movies ?
By JMGrande in forum Newbie / General discussionsReplies: 1Last Post: 13th Oct 2009, 16:46 -
Viewing downloaded movies
By orangekrush in forum Newbie / General discussionsReplies: 8Last Post: 16th Dec 2008, 04:10 -
How will HDCP affect downloaded movies?
By EatMoreChickens in forum DVD & Blu-ray PlayersReplies: 5Last Post: 29th Jan 2008, 10:31 -
storeing my downloaded movies as data
By dgavob in forum Newbie / General discussionsReplies: 20Last Post: 10th Nov 2007, 01:21
