  1. I have an episode of a show that I want to convert from its original RM to MPEG (for VCD). I have used TINRA to convert to AVI, but that file has audio that is out of sync. I have no idea how to fix the sync.
    I followed the guide on this site and it says to use Virtualdub to fix the sync problem, but I have no idea how to.
    Any help is greatly appreciated.
    Thanks,
    J
  2. Try Eo Video first. I believe the site is www.eovideo.com. I used it to convert South Park episodes to avi, then used tmpgenc to turn them into mpg. They turned out fine. No sync problems. Give it a try.
  3. Sorry the above link is wrong. The correct link is www.eo-video.com. Hope this helps.
  4. As luck would have it, I am trying to convert a South Park episode. Tried EO Video, and the new AVI file is in sync!
    Thanks a lot, friend!
    -J
