what is the best program for combining multile m2v's? beacuse:
my overall plan is to :
1) rip 3 unencrypted dvd's of home footage, ending up with multiple m2v's and ac3's.
2) combine the m2v's with____? (this is where u come in!) and ac3's using cat method.
3) export the single, combined m2v to a lower bitrate in QT Pro so it will fit on 1 dvd-r. (using QT mpeg-2 component)
4) then build the disk by putting this newly produced m2v and the single, combined ac3 in DVDSP.
do u think this will work, or is there additional steps i need to include? this is my first time downsmpling so i consider myself a newb to it. your help is greatly appreciated, so plz post comments or tips. THANK YOU!
hmmmm
i encode my movies in blocks of 40000 frames(due to limited amount of time i get to use computer) with CCE. by the time i finish the 1st disk i have about 3 or more mpv's(isnt that the same as m2v?? coz my mpv's are mpeg-2)
now i use tmpgenc - mpeg tools at the cut/join. i choose add - then i must type in *.* to view all files, then i select my mpv's in the order they fit together and then choose an output file and click run.
it has worked every time for meDeath, is only the begining -- Imhotep -
wow ur really trying to do alot....i use spruce up to recombine
m2v files w/ac3...they recode them to vob/ifo structures
u could probable just renumber the vobs and use ifoedit to
restructure them,tryed this with trailers and used no menu's
came out ok,but wouldnt play on every deck i got.... -
ummm yea... in case u didnt notice, this IS the MAC video forum, so if anyone has any solutions for a macintosh plz help me out. thanks. plz dont post pc solutions in the mac video forum, thank you.
you can combine multiple mpeg's using a program called extractor. you can find it here; http://denisx.dyndns.org/extractor/
Combining multiple titles into one
By augerpro in forum Video ConversionReplies: 2Last Post: 22nd Sep 2011, 16:50 -
Combining Multiple PGC's
By wulf109 in forum Authoring (DVD)Replies: 1Last Post: 25th Mar 2011, 22:38 -
m2v and ac3 multiple audio tracks to DVD
By gameroftheuk in forum Authoring (DVD)Replies: 7Last Post: 4th Aug 2008, 15:55 -
Program for combining RM files?
By Hikari112 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Sep 2007, 21:58 -
Combining multiple Titles into 1 (re-authoring a dvd)
By Liquid Drum Theater in forum Authoring (DVD)Replies: 33Last Post: 6th Sep 2007, 01:00
