I have a mpeg file can i convert this to a dvd file and make the quality of the video better? Also can some link me to a site with info on what is the difference between Mpeg -1 mpeg 2 mpeg 3 and pixels for video? Thanks
Ok some answers - you may not like them though
1 you can convert a mpeg file into DVD complient file
2 you will NOT increase quality - at the VERY BEST you will not change quality - most likely you will lose quality
3 YES - THIS SITE! look up the top left at the blue section
4 Mpeg 3 was dropped from the specs - this in not the same as MP3
MP3 is fully and correctly written as Mpeg 1 Layer 3 audio
If you want further information and or more technical details then goto www.mpeg.org - they have a lot of technical disections on the various mpeg styles.
I don't know what you mean by pixels for video
How do you guys convert mpeg-4 file into dvd?
By tendra in forum Video ConversionReplies: 3Last Post: 31st Aug 2010, 01:34 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
How can I convert a 1080i ".TS" file to DVD-compliant MPEG-2?
By kiwisoup in forum Video ConversionReplies: 2Last Post: 11th Jan 2009, 22:04 -
By kiwisoup in forum Video ConversionReplies: 1Last Post: 11th Jan 2009, 17:53
