I tried to open Nero burner but got a message saying that another application is using Windows burner engine (IMAPI). How to I close the other application, whatever it is? I've closed all the progams, so I don't know what else is there.
I also tried to burn a audio CD with Windows Media Player. But it's not detecting my CD burner. My CD burner is connected, I have even used it before both on Nero and Windows Media Player.
Restart the computer and open Nero first,if it still doesn't work,on your keyboard press control-alt-delete,a box should pop up showing you all the programs that are running. See if one of them is a burning program.
By any chance, did you have another CD burning application before you installed Nero? Such as Roxio/Adaptec's Easy CD Creator? That application has to be pretty much removed before Nero will work. (I had to go into regedit and remove every trace of the stinking thing before I could get Nero to work reliably. Uninstall didn't uninstall enough.)
Other than that, I suggest you check out the help forums at http://www.nero.com for ideas. Their forum is confusing and badly organized (which you wouldn't expect from Germans) but they have a lot of good information there.Animation and geeky reviews and podcasts at
Cartoon Geeks (http://www.cartoongeeks.com)
Error with Nero AAC encoder in XVID4PSP - "Could not open AAC encoder&
By TheViking in forum Video ConversionReplies: 2Last Post: 5th Nov 2009, 02:41 -
What's the best Open Source equivalent to Nero?
By OM2 in forum Newbie / General discussionsReplies: 7Last Post: 1st Feb 2009, 15:39 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 20:23 -
NERO can not keep a Data CD Open- no multisession
By src2206 in forum ComputerReplies: 4Last Post: 19th Aug 2008, 15:23 -
Nero won't open .mp4 file
By ChickaJane in forum Video ConversionReplies: 8Last Post: 22nd Aug 2007, 00:38
