I am using a Canopus ADVC-50 card and I am which is hooked up to my VCR.
I was wondering what would be the best program to capture from. I can't get VirtualDub to work, I am not sure I like Scenalyzer. Are there any other good capture programs to use with this card (or the DV format?)
Also I was curious between the difference betwen DV AVI (1), and DV AVI (2).
Thanks.
downer,
look for an app called DVIO.EXE
Its pretty small foot-print in size, and doesn't require a rocke-scientist to
operate. If and when you do find it, make sure you select Type 2 for your
AVI's. This way, vdub will work with them.
Sorry, I can't remember the link, but if you do a SEARCH on this FORUM
for the above file as its spelled, you'll probably find the D/L link.
Sorry I couldn't be of more help.
-vhelp -
no problem thanks for the help. i guess i am capturing fine with Scenalyzer, but when I encode with Tmpgenc i get a few things:
1. it shows up "letter box" when i play it back on my dvd player. that is not full screen
2. i see some flickering lines at the bottom of the picture (do to VCR), i am sure there is a filter to correct this but i am not sure what it is.
I would really like to figure out why it is not going full screen, i am using all the guides and I am doing 1:1 VGA, full screen (keep aspect ratio), and I am also choosing non interlaced.
any suggestions would be appreciated.
thanks
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 12:42 -
capture advice: USB 2.0 video capture adapter?
By j jasper in forum Capturing and VCRReplies: 10Last Post: 26th Feb 2008, 20:18 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 19:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 20:42
