  1. Hi there, I am using ATI MMC 7.1 software to capture to XVCD, but when I burn and play the video on my TV the audio is real choppy and it cuts out. When playing it on my computer the audio is fine. Also when I capture to VCD compliant mpeg everything is fine. My question is could capturing to xvcd be the problem, and/or how do I fix this. My DVD player plays XVCD because I have downloaded movie clips and burned to XVCD. Had no problem. Thanks
  2. Member DJRumpy's Avatar
    Dallas, Texas
    Your player may support xVCD, but you may have exceeded it's capabilities. Make sure you check your manual to see what maximum bitrate it supports for xVCD.
    Check both the audio, and video.
    Impossible to see the future is. The Dark Side clouds everything...
