  1. Im using a VCDHELP guide to fit a movie on to one disc in VCd format
    When i load the file up in windows media player it says the movie is 96 minutes (1hour 36 minutes.) But when i go to encode to VCD using TMPGEnc 2.5 it says the movie is 284min. When i click to encode it says it will take something like 8 hours.
    It is only on certain download movies that it does this.
    Has anyone else encoutered this problem, or know how to get round it?
    Details of the file format r below:
    IMAGE:
    Width 512 Pixels
    Height 384 Pixels
    Audio
    Duration 01:35:39
    Bit Rate 129kbps
    Audio format MPEG Layer-3
    Video
    Frame rate 23frames/second
    Data Rate 125kbps
    Video Sample size 24 bit
    Video compression DIVXMPG4 V3
    Any help would be great
    Chase
  2. Hi Angel,i have this problem before.I converted the aduio to wave with virtual dub first and then when I used tmpge the time would be normal.
  3. ok downloaded virtual dub. what do i do with it?
    Ive notused thisprogram b4
  4. ok, i ripped AUDIO. Ive loaded the movie into tmpg and then the audio. encoded a small section, and when i came to play it back, there was pic,but no sound.
    Any ideas anyone?
  5. 1.File-open video
    2.Under Audio select Full processing mode
    3.Under audio again select conversion and then 44100
    4. select save wav
    Is this how you saved the wave.
  6. no,but im just gonna do it that way. Ill report if it works or not.
    thanx
  7. Did it adjust the time properly and BTW there are some pretty good templates out there that put an entire movie on 1 cd but unfortunately not all dvd players support VBR ,like mine
