  1. How do I set Powerdvd XP 4.0 as default player for Mpeg,Avi etc?
    "Today is only yesterdays tomorrow"
    A Yellow Submarine
    Go to your start menu, then settings, then control panel. In the control panel choose folder options and in that click on the file types tab. There is a list of all the registered file types, and if you click on a file type you can see what program opens file and also change that.
