when I record a vcd with two or more tracks with Nero(latest version) I put zero seconds for the interval between tracks, but when i watch the vcd on my dvd player there are always some seconds of interval
how can I avoid this interval ??
thanks for the help
Results 1 to 9 of 9
you can't. some dvd players still pause for a few seconds even though you put 0 seconds. luckily my dvd player doesn't really pause for more then 1/4 of a second between tracks.
Hi, thanks for your help. But I have a VCD not recorded by me that doesn´t has this space between tracks when it plays on my dvd player ...
Are you sure that other disc was multitracked? Perhaps it used "entrypoint" chapters: http://www.vcdimager.org/guides
You will invariable get at least some sort of pause between tracks on a multitracked VCD.
Regards.Michael Tam
w: Morsels of Evidence -
Hi,
I am also from Brasil, Rio.
Yes, if there is more than one video clip there will be some small interruption.
Probably the other VCD is a one video file, authored with chapters.
If you want to make chapters etc... try DVD Workshop, from Ulead. -
Originally Posted by vitualis
Originally Posted by craigtucker
Regards.Michael Tam
Xvid4PSP key frame interval setting?
By x2x3x2 in forum Video ConversionReplies: 0Last Post: 30th Dec 2010, 23:19 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 01:56 -
USB Capture Card that supports capturing of VBI (Vertical Blank Interval)
By veganjay in forum Capturing and VCRReplies: 2Last Post: 12th Jun 2010, 11:36 -
Audio tracks
By siluet in forum Newbie / General discussionsReplies: 2Last Post: 17th Sep 2009, 21:07 -
Convert DVD to JPG sequence by any second interval?
By omega_weapon in forum EditingReplies: 3Last Post: 29th Jan 2009, 17:01
