I crashed my OS and had to re-install everything. Now v-dub nor iuVCR is capping my audio and everything is upside down.......
HHHHEEEEEELLLLLPPPPPPPPPPPPPPPPPP!!!!!!!!!!!!!!!!! !!!!!
easydvd,
can't help you w/ your Upside down issue, that's a codec version issue
there (but, see below anyways)
Audio,
you'll have to go back into Spkr (dbl-click) and make sure [x] is checked
for Line-In. This is usually a one-time thing, unless you have other software
that changes this from time to time.
Un-install, and Re-install process order usually:
1, codecs - get those codecs out, else driver may be influenced
2, display drivers
3, directX
4, capture drivers
5, directX (cap drvr app does this)
6, codecs - ie, divX, pic, huffy, other ie, ATIYUV12, etc., etc.
7, fix any left over codec issues by testing w/ vdub ie, load in an avi
... file/information, see what's in their. Anything not displaying, that
... used to be, is a codec issue
Manually re-installing a codec can be a pain in the butt. I had to re-install
my ATIYUV12.DLL codec cause vdub would not open files that were
captured w/ this codec. I like this codec a lot. It's the cleanest and
sharpest (imo) so, it was worth the headackes of manual install.
Hoping that the above works out.
-vhelp -
ok. I got my sound back when I re-installed the ATI MMC stuff. I also un-installed the card, sourceforge drivers and then re-installed all of it.
the drivers are a newer version than I had before(sourceforge) anyone got the last ones from oct?
ALL of the caps seen to be upside down.......no matter which codec I use which leads me to believe a driver issue. Gonna un and re install them anyway. I'll get back to you
Can I put just that ATI codec in without all the rest of the stuff? -
LOL. I had that problem once playing DivX movies. That was fun :P Fixed my part by overwriting the codecs too. Good luck
ok...
un and then re-installed ALL of it and everything seems to be ok.....I hope.
Thanks!!!!!
