I have just started to convert VHS tapes to SVCD (and eventually DVD-R).
When I go through TMPGEnc and select NTSC SVCD and go through the settings, the audio is set to 128kbs. and it is greyed out and won't let me change it. I tried opening the template and it says it is set for 224??
Anyone know how I can get this to change?
Thanks.
Cancel the wizard and go stright to TmpGenc. Select your source video and Audio first. The click the load button and lod your template. Click the load button AGAIN and open unlock.mcf from the TmpGenc extras folder. You will now be able to change all settings.
TMPGEnc Video Master Works audio problem creating bd25
By necron99 in forum Video ConversionReplies: 0Last Post: 29th Apr 2012, 19:52 -
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
TMPGenc Audio Problem
By Iwan2learn in forum Authoring (DVD)Replies: 5Last Post: 13th May 2009, 09:27 -
Audio Problem using AVISynth and TMPGEnc Xpress
By 1980sumthin in forum Video ConversionReplies: 10Last Post: 27th Jan 2009, 05:27 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 02:41
