Hi all,
jus a newbie qn....pls dun flame me
I'm using a Duron 700Mhz . Does it help in ripping and conversion if i get say a Good GFX card with Video Processing Engine (VPE) such as a Geforce 4MX 440?
Me not enuff $$$ to get a new system so was wondering if a good GFX can do the trick.
Thx for reading
New video card is not what you need. You need DVD-ROM Drive and at least 10gigs HDD space.
May the force be with you. -
Actually, I'm ripping DVD now with 2.5 gig of space and a 400 MHz CPU with good old NVIDIA TNT. So you don't need 10 Gig of space. It's mainly CPU speed, patience, and knowing the setup. Having more space helps as ripping the whole thing to HD makes things easier, but it's not required.
yea....CPU is the main determinant of encode time, given constant tmpgenc settings...
don't expect anything less than 12 hrs to encode with a duron 600 mhz...my old athlon 650 takes about that long w/o any filters...if i use any, that comp takes alot more time....
if your mobo can support, try just upgrading the CPU.....athlon xp's go for $100 now
www.newegg.com
Minimum System Requirements for capturing miniDV
By darkwhite in forum ComputerReplies: 19Last Post: 27th May 2012, 08:21 -
Minimum System requirements for Bluray ripping/burning?
By orbital517 in forum Blu-ray RippingReplies: 12Last Post: 28th Oct 2010, 12:32 -
System Requirements to Rip/Convert Blu Ray
By minerva.thegift in forum Blu-ray RippingReplies: 5Last Post: 23rd Sep 2009, 00:16 -
Minimum system requirements to play 720p files?
By ukb007 in forum Newbie / General discussionsReplies: 11Last Post: 21st May 2008, 14:36 -
HD system requirements
By kippard in forum Newbie / General discussionsReplies: 25Last Post: 20th Jun 2007, 03:05
