JAW gives me a first chunk that works, and several that don't. Tried a bunch of settings. Anyone got any ideas? Another program? (Running 10.2.2). I remember extracting working MPEG-2 streams from partial .bin's, so maybe I need to make a .bin of the 2.2GB MPEG-2, split that w a file splitting program that allows files over 2GBs (any ideas?) and then extract the MPEG-2s, re-bin them and burn... damn that sounds like a pain... any ideas on a bette way?
My fault of course; forgot to click the right boxes using ffmpegx LOL... seems you can't get it to split the files after the fact... pity, that's the fastest and best splitter I've seen/used...
/Wizeman
"I have not failed. I have only learned what does not work."
-Edison -
The GUI is not too self-explaining and certainly needs improvement, but ffmpegX 0.0.4g allows for splitting without encoding.
Use the Mpeg-Tools tab, open the video in the right side (no audio if your mpeg file contains both video and audio) select the split and author options as usual, then select "Postprocess (split&author)", uncheck "Mux" and "Demux", and hit "Go!". -
OK; great news! I tried it now but must have done something wrong anyway, because this is what happened... any thuoghts on that?
/W
Last login: Sun Nov 10 17:54:13 on ttyp1
pbpaste | sh
Welcome to Darwin!
[dhcppc1:~] wizeman% pbpaste | sh
Size of Fix: 0x20
now reapplying junk-header ....
Now processing /JackieFull/Jackie SVCD/JBsvcd.mpg [1/3] ...
*** malloc_zone_malloc[394]: argument too large: -173
sh: line 1: 394 Abort trap /Video/ffmpegX.app//Contents/Resources/mpgtx -s -P -N -3 /JackieFull/Jackie\ SVCD/JBsvcd.mpg -b /JackieFull/Jackie\ SVCD/JBsvcd.mpg
Processing complete!
Just tried again w another file, and then it workled (!) But not with this one... odd..."I have not failed. I have only learned what does not work."
-Edison -
Something just5 occured to me; there is one difference between the two mpeg stremas I tested... the one where the splitting worked had a bitrate of 2500, the other (where only the first part worked and then got "invalid" for the rest) is bitrate 1900. Could this be a factor?
-Edison
Best freeware MPEG-2 splitter?
By ANOther1676 in forum EditingReplies: 26Last Post: 4th Feb 2011, 16:59 -
Haali MPEG (PS) Splitter
By zawmn83 in forum Newbie / General discussionsReplies: 0Last Post: 14th Jun 2010, 00:33 -
MPEG Splitter
By Amanaman in forum Newbie / General discussionsReplies: 12Last Post: 5th Sep 2009, 16:28 -
MPEG-2 Splitter?
By therock003 in forum Software PlayingReplies: 1Last Post: 22nd Jul 2008, 12:24 -
Jaw-dropping Photosynth demo
By thecoalman in forum Off topicReplies: 2Last Post: 29th Jun 2007, 04:20
