Hello,
I wanted to add a brand of DVD media to the DVD Media List.
I downloaded ADVDInfo and ran it but it crashes instantly.
I'm running Windows XP. Compatibility problem?
I have a Sony DRU500A DVD Recorder, Maybe it doesn't support
that yet? Does it need a DVD recorder or will it work on a DVD-ROM drive?
Thanks.
You'll want to put the EXE file in the system32 directory under the Windows directory. Then you can make a shortcut to it. Try that and see how it goes.
Regards,
Savant -
Tried it... Same problem. Maybe it just doesn't run in Windows XP?
Tried the program on a Windows 2000 machine and it runs fine.
Unfortunately that machine only has a DVD-ROM drive and it won't
give the disk mfg id...
Oh well... -
It doesn't work on my WinXP (Home Edition) too.
When I run ASPI Check this is result.
ASPI32.SYS --> 4.71.2
WOWPOST.EXE --> 4.6(1021)
WINASPI.DLL --> 4.6(1021)
WNASPI32.DLL --> 4.71.2
Anything between 06 and C0 doesn't work
OK.... I just found somewhere that this problem might be media related issue. It should work on -R/-RW but not on +R/+RW. Am I right ? -
Can anybody confirm if ADVDInfo doen't work for +R or +RW media. And if this is realy true... How do you identify + disks ? Is there another tool for this ?
Partial solution... I use Nero CD Speed 1.02 to get manufacturare name and code from +R and +RW disks for now.
Can you please help identifying this file ?
By fa355115 in forum Video ConversionReplies: 1Last Post: 23rd Jan 2012, 08:27 -
Identifying OS on DVR HD
By juststarting in forum ComputerReplies: 6Last Post: 24th Feb 2010, 00:29 -
Problem identifying file...
By extreme85 in forum Newbie / General discussionsReplies: 8Last Post: 15th Aug 2009, 10:23 -
Help identifying this drive
By Noahtuck in forum DVD & Blu-ray WritersReplies: 32Last Post: 20th Feb 2008, 01:19 -
Help identifying drive
By thekfc in forum DVD & Blu-ray WritersReplies: 3Last Post: 14th Jan 2008, 08:28
