When I capture videos from my DV camera it gets darker and bad quality on the computer!How do I get the same quality as it is on the DV camera?
I have used Pinnacle studio to capture.Should I use another program to capture?
/Roberth
Thanks in advance
(excuse my bad english)
Suggestion.
Change the title of this post to:
"Pinnacle studio DV camera capture quality"
You might get more people reading your question if the title gives them more details.
Just a suggestion.
wway -
Same problem here. But I heard that once you convert it to MPEG1/2 and write to VCD/SVCD/DVD, you will get the quality you expect.
Did you try to capture same file back to tape to see if quaolity remains bad ? Maybe its just computer setup isuue and not realy data issue.
Yes I have.Butt the camera didn't see anything so it didn't work.Do you know which program is best to capture in?I have this far capture in Pinnacle Studio!Butt it is not a good program.I have adobe premiere 6.5 butt I haven't tested to capture in that.
No I don't know what is the best.
I use Studio 7.
Why don't you like Studio ?
DV capture quality sucks
By cooldude859 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 36Last Post: 28th May 2008, 16:07 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 19:05 -
Problems with Capture Quality
By drxpsp9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 25th Jul 2007, 23:53 -
How To Capture in better quality Help??
By Force21 in forum Newbie / General discussionsReplies: 1Last Post: 27th Jun 2007, 17:46 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 20:42
