Hi,
Can anyone tell me how to fix bad and undecodeable frames? or how to fix the problem of receiving the error message "internal error mmx" also when reading in an MPEG, the error message "MPEG import error, packet sync error on packet stream"????
Appreciate any help
To fix bad frames, use virtualdub.Originally Posted by FruityGibbon
Start virtualdub, open your avi.
Video->scan stream for error (this will take a few minutes)
Once you have don this you can either frameserve fro virtualdub to your encoder (see guides for info) or save out a new copy. To do this select Video->Direct stream copy, Audio->direct stream copy, File->Save as Avi.
As for packet sync error etc, if this is from vdub, it means you are tring to open an mpe-2 stream. Virtualdub will not open mpeg-2.
Don't know about the mmx thing, sorry.
Video in Virtual dub out of sync
By lituvis in forum Video ConversionReplies: 0Last Post: 7th Mar 2012, 09:56 -
Virtual Dub Mod video combining?
By wcdeich4 in forum EditingReplies: 1Last Post: 18th Dec 2009, 07:18 -
How to change video resolution exactly in Virtual Dub Mod 16:9 to 4:3
By afcoff in forum Video ConversionReplies: 1Last Post: 12th Jan 2009, 11:49 -
No Video In Virtual Dub, Just Audio
By AllenM in forum EditingReplies: 11Last Post: 3rd Oct 2008, 13:35 -
Audio problems with Plextor M402U and Virtual Dub
By nrsgzz in forum Capturing and VCRReplies: 4Last Post: 6th Sep 2007, 17:27
