Hi guys. I got an avi (frameserved thru tmpgenc using virtualdub for subtitles) with a few bad frames in it - i asked some other ppl about fixing the bad frames and this is the answer i got :
" If you want to convert the file to another format like SVCD, you can use a program called AVIIndexgenerator and a hex editor to patch the file (set the size of the bad frame to 0 bytes) so VirtualDub won't stop at the bad frame. "
my question is is this possible and what do i have to do?0 ( cause im a newbie)
ok i'll try it thanks for the assist
don't mean to be rude tho, but you didn't really answer my question.
if im not mistaken, doing it the way in the guide would mean losing the bad frames right? what i would like to know is whether there is a method of preserving the bad frame so that VirtualDub won't stop at the bad frame while frameserving using the method above? -
i cut the bad frames out but now the subs are out of sync with the audio. How do i fix?
Premiere CS3 exporting bad frames
By spicediver10191 in forum EditingReplies: 4Last Post: 17th Apr 2012, 18:39 -
VirtualDub - fixing bad frames with blending and without re-encoding
By spicediver10191 in forum Video ConversionReplies: 3Last Post: 11th Apr 2012, 09:15 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 16:00 -
.avi file cannot be repaired - need to remove bad/corrupt frames
By realtechtalk in forum Video ConversionReplies: 0Last Post: 7th Sep 2008, 13:27 -
Cutting bad frames with VirtualDubMod
By lazaruz in forum EditingReplies: 2Last Post: 18th Sep 2007, 04:39
