I usually do most my svcd rips at min - 1800 avg 22-2300 max 2400. Since it'll fit most movies on 2 cd's.
Last night I encoded a movie that was a little longer then usual, about 214K frames or about 2 hours.
I was going for a 3 cd version of it and basically used standard svcd settings for the avg (min 1800 - avg set to 2520, max 2613) but VBR-2 Pass as usual and highest quality.
Normally for a 180K frame movie it takes me about 5.5hrs to do.. for whatever reason, this one took 12 freakin hours. I must have set something differently, but i can't think what - i always use highest motion setting.
system is a XP1700, 768MB PC133, 320 Gig.
-d
more bitrate will take longer...
however, 1 thing to lower your time is that motion search accuracy...try setting that to high quality (slow), instead of highest quality (slowest)....the latter doesn't improve the quality very much (if at all), but adds alot to your encode time
Run-time hell - Longer on camera than on copied file on hard drive
By Qwerty69 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 2nd Jul 2011, 17:12 -
When you say Encode it for X bitrate...
By Priapism in forum Video Streaming DownloadingReplies: 9Last Post: 12th Sep 2009, 00:30 -
Solved: How to change forced hidden attribute of folders/files
By jimdagys in forum ComputerReplies: 0Last Post: 1st Jul 2009, 00:07 -
Does YouTube give some users a longer time limit?
By brassplyer in forum Video Streaming DownloadingReplies: 3Last Post: 27th Aug 2008, 01:49 -
Time Warner Cable & HBO No longer as of this Week allow you to Record
By dogtales in forum Capturing and VCRReplies: 69Last Post: 1st Dec 2007, 18:17
