  1. i just dl d.c. from http://www.neo-modus.com/..... can anyone tell me how to connect or use the software..... i want to dl some things because it seems kazaa is getting a little slim on quality products or products at all these days
  2. D.C is my favourite file sharing program. you have to specify what files you are willing to share, you do this in the settings/ file transfers tab. the more gb's you share, the more hubs you get into. then klik on connect at the top left of the page. next klik on "public" in the box that opens up. double klik on 1 of the hubs and you're there. be sure to share as many gb's as you can cos these hubs are a bit fussy about that. when you're in a hub, use the search facility to find what you want. hope this helps
