are there softwares out there i can use to convert mpeg to divx format without decreasing the quality of the video?
No matter what you do, there will be some decrease in quality. The two formats are totally different so you will be decoding one and then encoding into the other. This will always lead to a decrease in quality. All you can do is attempt to minimize the drop.
Good luck,
Ian -
To Ian:
i have another question for u if u dont mind. give me some names of software that i can use convert from mpeg to divx format? thanx in advance for all ur troubles.
<font size=-1>[ This Message was edited by: thanggnguyen on 2001-08-24 09:39:25 ]</font> -
Yo Man, the best programme to use is VIRTUAL DUB.
Here's a link to site that will tell you how to convert mpeg to AVI\DIVX.
http://www.digital-digest.com/nickyguides/vcd-2-divx.htm
enjoy
Lots of other digital video editing proggys can do it. Adobe Premiere, Ulead Media StudioPro, Vegas Video...
Really, all you need is something that can open an MPG and save an AVI and allows you to specify the codec.
Personally, I'd go along with marvel2020 and use VirtualDub.
Good Luck,
Ian
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 02:26 -
Batch convert ISO to AVI/Divx/MPEG
By extrememc in forum Newbie / General discussionsReplies: 1Last Post: 11th Jan 2010, 18:13 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Command line method to convert MPEG-2 to Divx Home Theater Profile
By CLIjunkie in forum Video ConversionReplies: 15Last Post: 6th May 2008, 21:22 -
How to Convert 1280*720 DivX to a less dimensions DivX
By firas_hashim in forum Video ConversionReplies: 9Last Post: 27th Jun 2007, 08:33
