Here is a question I'm not sure where to post so I'll start here.
If I rip a DVD and convert it to svcd format can I then author a dvd-r with each of the svcd files as a chapter?
SVCD format is not valid for DVD and you cannot burn SVCD to DVD media. There is a gude on this site (under authoring I think) on how to get SVCD video onto DVD-r but it is not compatible with all players.
Thanks Bugster,
I think I've figured it out. Tell me if this sounds right:
rip to hard drive (smart ripper)
convert to avi (DVD2AVI)
reconvert back to dvd format (TMPGEnc w/VFAPI and Chapter-X-Tractor)
author a new dvd-r (VCDEasy, DVDit,etc.)
Sounds simple but I know there are a number of steps involved. Do you or anyone else know an easier way? -
There are plenty of other ways. You certainly do not need to convert to an avi first (I mad this mistake when I started out too!). The method I use now is very similiar to the one posted here:
http://www.vcdhelp.com/forum/userguides/121195.php
at least I use this guide as far as ripping is concerned, I encode with TmpGenc in the same way as the guide uses CCE (just change the settings in DVD2SVCD appropriatley). Then I author with Spruce. There are plenty of other guides on the subject of ripping DVD to DVD-r if you look around.
How do I make an MPEG-2 dvd compliant file into a authored dvd?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 13Last Post: 12th Mar 2009, 16:10 -
Burn authored VIDEO_TS as UDF or CDFS (or RAW) file system format?
By PCat in forum Authoring (DVD)Replies: 4Last Post: 26th Jan 2009, 17:33 -
How do I edit DVD-Video and place back into the authored DVD w/o errors?
By Stealth3si in forum EditingReplies: 3Last Post: 12th Sep 2008, 06:48 -
Authored DVD exceeds DVD spec bitrate - advice needed.
By outerspacerace in forum Authoring (DVD)Replies: 27Last Post: 14th Jun 2008, 23:23 -
How to Make Authored DVD INTO .ISO WITH TMPGENC DVD AUTHOR
By Chupes in forum User guidesReplies: 4Last Post: 19th Aug 2007, 18:38
