First when I load the IFO file its not the same length as the dvd states..
Example, I load in Armegeddon-- DVD2SVCD says movie length is 2:43, but the dvd box says its 151 minutes (2:31)..
Second, when I choose 800 cd size in the bitrate settings, then I encode in CCE 2.5 the log says that cce is using cd size is 740..
Also, is 9 1/2 hours for encoding about right for this length of movie?
Using these settings.
Force film on in dvd2avi
CCE 2.5 settings are as folows:
Anti Noise Filter: 2
Passes: 2
Image Quality: 17
VAF file creation: On
Video Encoding Mode: Multipass VBR
Min. bitrate: 300
Max. bitrate: 2530
Avg. Bitrate: 2230
Aspect Ratio: 16:9 (borders added, encoded as 4:3)
No audio downsizing ( 192@48 )
Bye For Now..
Buzz
	do 3 passes if you want decent results...4 passes if ya got the time and it sounds like you don't.
 Don't worry about it...dvd2avi will analyze the total time of the movie. But the rule is set your bitrate parameters according to what dvd2svcd says is the movie length.
  intensity pro quick couple of questionsBy digitalpimp in forum Capturing and VCRReplies: 8Last Post: 31st Dec 2011, 18:22
  intensity pro quick couple of questionsBy digitalpimp in forum Capturing and VCRReplies: 2Last Post: 23rd Nov 2011, 19:34
  A Couple of Quick Avidemux questionsBy Seeker47 in forum EditingReplies: 3Last Post: 16th Mar 2010, 04:20
  Couple quick Panasonic AG-1970 questionsBy pgoelz in forum RestorationReplies: 13Last Post: 4th Mar 2010, 18:22
  a couple of questions ..By ZaYoOoD in forum AudioReplies: 6Last Post: 7th Mar 2008, 15:21
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
