Hey. Say I capture a movie or something, to AVI, with that lossless codec.. and then I use Adobe Premiere to edit it, cut or add transitions or whatever.
Then what? If I want to export this project to a VCD or SVCD with GOOD quality, such as TMPEGENC, is that possible? I find Tmpegenc the absolute greatest when encoding SVCD's .. hmmm does anyone have a tip?
In order to use TMPGEnc with Premiere you MUST frameserve with AVISynth. Go the the AVISynth site and read the tutorials, get the correct version, .03 Beta I think it was... and you should export to AVISynth, and launch TMPGEnc and do what the tutorial says. This will let you export your Premiere Timeline to TMPGEnc and the template you have loaded. If you want more ease of use and don't NEED it to be SVCD, just export using Panasonic MPEG Encoder plugin for Adobe Premiere.
irc.webmaster.com port 6667 #DDR -
cant you just export the adobe file as avi uncompressed and then try encode the file with a simple avi2vcd program?
F1!! F1!! F1!!! -
Hehe.. well first I capture to AVI, and it takes like 1 gig / minute or something like that, at 704x576 which pretty much fills my harddrive up.
I can't just save the file to another AVI afterwards, because then I would need another harddrive (or one that is twice as big).
It's as simple as thatThanks for the replies guys!
Go with TIbrO's suggestion; Won't cost You (much) extra harddisk space, and it is quite fast (IMHO). This is the way I work with Premiere for MPEG output, and I've tried a lot of various solutions. The only time this failed was a on a series of short MPEGs, where I ended up using another Premiere plugin-encoder...
/Rico
Exporting from Adobe Premiere Pro not working
By Devilsadvocate in forum EditingReplies: 1Last Post: 29th Mar 2012, 11:04 -
adobe premiere CS5 video exporting issue
By bteamstephen in forum Capturing and VCRReplies: 4Last Post: 11th Dec 2010, 00:55 -
Adobe Premiere Pro CS3 Write Initialization error when exporting
By dzsoul in forum Video ConversionReplies: 3Last Post: 21st Nov 2009, 18:23 -
Adobe Premiere Elements is cutting off the end of video when exporting
By robvs in forum EditingReplies: 0Last Post: 19th May 2009, 17:47 -
Editing and exporting already compressed video in Adobe Premiere
By Rocky88 in forum EditingReplies: 4Last Post: 31st Jul 2007, 08:52
