in the conversion section there is one guide for converting .rm files but the program it suggests you use is not made by that company anymore ... does anyone know of another program that could be used or another guide somewhere ?
thanx.
Madhatta, out
Try Eo Video (http://www.eo-video.com/). I've used it recently to convert some South Park episodes. It works great. Convert to avi with Eo Video, then to mpg if you need to with TMPGEnc. Hope this helps.
how long does it usually take to convert an episode of soutpark (thats what I wanted it for also)
Madhatta, out -
It took me about 22 minutes to convert it to avi in eo video. Then it took me about 12 minutes to convert to vcd format in tmpgenc. So about 35 minutes to convert an rm south park file to vcd format.
ok well I am doing to avi only ... so i will try that .... what bitrate do you recommend for divx 5 ?
Madhatta, out -
i moved it down a bit cause i want all of one season to fit on one cd
i moved it to 400 and it looked pretty decent
madhatta, out
DVD to AVI Or MPG
By AeR0 in forum DVD RippingReplies: 10Last Post: 4th Mar 2010, 18:59 -
mpg to DV-AVI converters
By nuttyDeedee in forum Video ConversionReplies: 7Last Post: 31st May 2009, 17:13 -
AVI to MPG for authoring?
By chronic777 in forum Video ConversionReplies: 2Last Post: 25th Sep 2008, 10:43 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
avi to mpg
By zoranb in forum Video ConversionReplies: 7Last Post: 12th Sep 2007, 15:09
