hello i have downloaded an avi file which is 1.30hr long but i only have a 80 min cd so how can i split the file into two halfs so that i can put say 1 hour on the first cd and 30 minutes on the second.
please can you help me
thank you for your time
da kevster
alternatively you could make an xvcd that would allow you to burn up to 2 hours of material onto an 80 minute disc. of course yor stand alone dvd player would have to support this.iv'e done loads of these discs and never had any compatibility problems from friends who've borrowed them. the quality of the finished article depends on the length of the movie but i've quite often had bitrates that are higher than the standard vcd, even a couple that approach svcd bitrates. the guide on how to do it can be found on this site.
kevster,
You didn't mention in what format did you want to put your file on CDR/RW. If you want to keep it as AVI then it has to be burned in Mode 1 (data CD) and it doesn't matter how long is your movie as long as it is no bigger than 700MB for 700MB CDR (so it could be 4 hours long and still fit onto 1 CDR). If you are encoding it to (S)VCD then it matters, you could use Virtual Dub to split it in half and encode each half separately OR split it in your preferred encoder when setting everything up. All the HOW TO's are provided on this site.
Regards.
Split AVI
By niol1000 in forum ProgrammingReplies: 1Last Post: 9th Jun 2010, 17:49 -
AVI Split - The right way?
By B11 in forum Video ConversionReplies: 1Last Post: 25th Dec 2008, 13:47 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 00:00 -
avi split files
By bally in forum EditingReplies: 10Last Post: 24th Sep 2007, 18:17 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49
