  1. ok, here is the problem: I'm using VDCEasy, but I'm not using Cdrdao. I did everything as the guide http://www.vcdhelp.com/divxtovcd.htm (and I added chapters I did on my own) and then hit the "go" buttom. In the "log" window, when finished, it appeared "finished ok, image created with 354291 sectors [78:43.66]". My question is: what do I do next? In the guide, it seems after I hit the "go" buttom, the cd would be recorded, but my cd is still empty. and there is no other buttom to hit on...
    I was wondering if the problem is that I didn't use cdrdao, but I read you can burn without using it, so anyone know the problem and, more specifically, what do I do from here to burn the cd?
    thanks.
    take care!
    Apr 2002
    The State of Frustration
    It created a VCD image for you. If you want to burn a VCD, you need the burn software. You can use CDRAO, or Nero, etc., but VCDEasy does not burn VCDs.
    Hello.
  3. thanks!
    and if I use cdrdao that is in VCDEasy? Then, will it burn?
