I just hooked up my new ADVC-50 card to my computer and I have hooked in my VCR to the inputs.
I was following the guide and I get some errors. When I select custom video format and i change the settings to 480X480 and YUV2 4:2:2 it says unsupported format.
Also I have installed the huffy codec (right clicked on the inf and chose install) and when i go to video compression I don't see anything but no recompression: YUY2 as a choice.
Anyone know why this might be happening?
Although the guide is a pretty good guide, the custom resolution portion is not effective for all capture cards. I suggest you capture at the best rate your card can handle with as few dropped frames as possible, while still giving you quality you like.
Then use your favorite encoder (mine is TMPGEnc) to convert your video to the format you need.Hello.
Virtual Dub setting help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 10Last Post: 27th Oct 2011, 18:55 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 14:48 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 16:36 -
how can I specify the resolution when capturing in virtual dub?
By Onceler2 in forum Capturing and VCRReplies: 3Last Post: 28th Jan 2008, 11:11 -
Virtual Dub Mod
By OG24 in forum Newbie / General discussionsReplies: 11Last Post: 8th Aug 2007, 16:36
