i rip my spiderman and ran it tru ifo edit and it burn wit no prob using primo 2..... well in da middle of the movie and certain other places the video jerks a little then do it thru the whole thing.... is there anything else i need to chge ??????? or is it the media
yea.... i because i just found out it dont do it on my apple dvd r's....... but i also dont think there are optodisk like a certain company said they were...... i wll have to check it out because REAL optodisk dont act like that
i kinda had the probelms ur seeing,pls dont bomb me....
ifoedit gets kinda tricky,
1st------which version u using? i use 088 now...
media probably isnt the problem...
2nd---are you using spidy menu??
i gave up on menus,since i hate coasters,sometimes
ur video_ts.ifo's get messed up there,use ifoedit to create
new video_ts.ifo/vts_01_0.ifo and menu problems go away...
3rd-- you processed all ifo right?....here's kicker,dont forget
to save vts sector thing,just in case
Just so u know, i ripped spiderman last week, with no menu's
no subs, no commentaries,no 2nd lang's, and it plays in
3 dvd players i have with no jittering afore mentioned,hope
this helps...(*::::: -
yea it is and no it aint..... let me explain..... i did some researching.... i played apple copy on a couple of dvd players and there was no problem at all but when i played the genric disk on some players it did happen on certain players.... but it happen on the no name or cheap ass players..... which is sayin CHEAP ASS NO NAME MEDIA AND CHEAPER ASS NO NAME PLAYERS DONT GET ALONG
Few things I noticed. (and been mentioned quite a few times).
1) The DVD player vs media compatibility will cause it to play or not to play. It rarely effects those pause for a moment problem. (with exception of computer DVD which seems way more tolerable for some unknown reasons). In fact some of cheapest DVD players are the most compatible as they flat out use those computer dvd drives in their housing.
2) Media plays very important role. Out of 10+ brands of -r/-rw media about 30% of them (usually the cheaper one) doesn't work well in my DVD as well as few friends. (I am sticking to merit line general brand or optodisc or samsung for now until i find further incompatibility issue with other players). Avoid princo, GQ like plague. They do stutter as you mentioned. Verbatim 2x is great but at $3 a pop... it does get expensive.
3) I myself burnt above mentioned dvd with no problem using ifoedit and nero. And it plays just fine with no stutter. One was meritline and the other was samsung. (Had to split it) Must have watched at least 3 times already with constant instream of neighborhood kid and guests.
My recommendation, go out and grab few decent media and see where problem really lies. It isn't IFO edit for sure. -
well i just bough some maxells from best buy and it was 35 for a 10 pack... since they was labled number 2 on compatibility i am gonna see if they work any better..... will let you no
Jerking action when I convert AVI to DVD - all help appreciated
By walpoo in forum Authoring (DVD)Replies: 1Last Post: 15th Apr 2010, 16:18 -
edit studio 6 jerking rendered material
By mistressa in forum EditingReplies: 1Last Post: 8th Sep 2009, 16:38 -
Problem of jerking in video while Converting DV to DivX / Xvid / DVD
By ckbasak in forum Video ConversionReplies: 7Last Post: 30th Dec 2008, 08:23 -
Frame jerking after converting movie to DVD
By lucontt in forum Video ConversionReplies: 10Last Post: 28th Jun 2007, 06:24 -
Winavi v8 SVCDs jerking with SVCD2DVD
By nawo69 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 13th Jun 2007, 16:02
