  1. Am trying to burn a divx onto dvd, have had success with smaller files which are aprrox 200Mb. But when i try to burn big dvd rip divx (van wilder) it seems to be very choppy. Can anyone help me. I am using TMPGenc 2.58 to encode
  2. 1) You, most likely, have posted this in the wrong forum. Should be under Newbies since you are dealing with DivX to (S)VCD conversion.
    2) What do you mean you're burning it to DVD? Aren't you trying to say (S)VCD?
    3) You need to give us more details about your encode to get help. So far i can only tell that it is a framerate or high bitrate problem.
