I have a program in my HD which I want to back up in a DVD-R since its size it aroung 2.5GB. The problem is that since its depth paths (subfolders) and path length (file name size) are more than the required by ISO. Nero tell me this when i try to burn. If i choose to rename, the program will not run since it will not find its files. If I choose to ignore this the DVD-RW drive will not even read the DVD. If anyone know what option should I choose so that I can successfully burn a program whose subfolders an
218
d file name are larger than the ISO standard, please let me know. thanks jacob.
Results 1 to 1 of 1
VOB2MPG and network paths
By kfealz in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 5th Jan 2010, 19:21 -
Using Super - can paths be changed?
By Will_Annand in forum Video ConversionReplies: 3Last Post: 4th Jun 2008, 13:24 -
Moving Paths/Keying Help
By Trunkz Jr in forum EditingReplies: 6Last Post: 10th Apr 2008, 18:01 -
Recovering Data from an Unfinalized disc with ISO Buster
By socool135 in forum Authoring (DVD)Replies: 13Last Post: 19th Jun 2007, 23:58 -
By socool135 in forum MediaReplies: 1Last Post: 17th Jun 2007, 03:21
