hiya!!
it's very annoying to have a clip not in sync after you have encoded for such a long time.
i'm using TMPGenc and can i check that in the source range before i start that??
and.....can i start encoding a clip from the middle without doing any cutting in advance??
i'll be glad if you genius can drop me a few lines.
thax a lot^^
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Look under the advanced tab in the TMPEGnc settings and you can pick the source frame (which I use to trim)
You should be able to view your source .AVI file with Windows Media Player. If your .AVI file has no audio then you can use VirtualDub and select the .WAV file as your source but that sometimes doesn't work because Virtualdub doesn't work fast enough. Virtualdub can't properly play .AVI files that Windows Media Player can.
and a lil advice, always just encode a few minsutes worth of mpg first..then stop it, check the mpg to make sure everything is how you want...THEN encode all the way through
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
audio out of sync? please check
By cesarin in forum EditingReplies: 4Last Post: 22nd Dec 2011, 10:41 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
How can we check video and audio bitrate for source DVD frmo Amazon?
By Bonie81 in forum DVD RippingReplies: 5Last Post: 21st Apr 2010, 16:14 -
how do i check the audio and video lenght?
By mrjust in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 19:51
