    Nov 2001
    USA
    Downloaded a DVD.SCREENER.XviD movie, which came in two parts.
    Using WinRaR to unarchived each part, I end up with two AVI files
    totalling a little over 700MB each. Running each file thru VirturalDUB,
    it shows the movie as being a NTSCfilm (23.976), and a running time
    of a little over a hour each.
    Using TMPGEnc v2.58.44.152 to encode the movie to SVCD, I go thru
    all the steps that I've used before, but I end up with Bitrate settings
    that are impossible to understand.
    Proposed medium of an 80min CD-R shows a file size of 3.4GB, and
    a movie running time of 169min. Using the default Avg. video bitrate
    of 2520, uses 431% of the CD-R. Which I'm sure you know is impossible.
    Lowering the percentage to my normal 99.98%/786MB, shows a bitrate
    of 412. Which again is unacceptable. Figures for part two are about the
    same.
    Any ideas what may be going on? And of course a solution!
    TIA
    Why doesn't this work?
    Nov 2001
    USA
    Since I haven't received any replies, I thought I'd try and help myself.
    I decided to try and burn a portion of the movie and see what it looked
    like. Granted the bitrate was only 400, but maybe the readings were
    just wrong, and it didn't make a difference in the quality.
    As soon as I finished the last setting and browsed to a directory to store
    the mpg, I hit OK. It immediately crashed and closed TMPGEnc. Now I
    am using the latest version, but prior to this I never had a problem with
    an older version I was using.
    Could the problem be software?
    TIA for any help!
  3. look here:
    http://www.vcdhelp.com/forum/viewtopic.php?t=119019
    and maybe other guides too.
    Nov 2001
    USA
    Originally Posted by bugster
    Bugster this looks like its going to work!
    The file size is down to something normal.
    I saw this guide, but I didn't think it would
    take care of the file size prob I was having.
    Thanks to you for pointing it out to me, and
    to O Kewl for writing it.
