  1. i needs some help.i get a error message everytime i try to encode and avi file in cce .the message is.COULD NOT FIND APROPRIATE VIDEO CODEC FOR DX5 .im running 2.5 cce
    need help bad can someone help me.please
    Aug 2002
    MiddleShire UK
    Are you frameserving to it ?
    You can't just load the AVI straight in on its own it won't work
    AVIsynth is a very good frame server, There is a very good AVIsynth guide wrote By Trueman under the guides ares you should check it out
