Here is my problem need help bad
I STart With my hardware first
Pentium 4 2.4 ghz
soyo p4vda motherboard via chipset
nvidia geforce 4 mx 420 64mb agp video card
sound blaster extigy external sound card
maxtor 80 gb 7200 rpm ata 133 ide drive
hp dvd 200i writer
generic dvd rom drive
hp scanjet 3300c scanner usb port
hp 855c printer
us robitics 56k modem external com 1
okay now on to my problem
got my advc100 already purchased siig firewire card found out it had the texas instrument chipset could not get it to capture mor than 2 minutes.
took it back and got pinnacle studio 8 dv with firewire card and software also have video deluxe 2.0 plus on computer also still unable to capture for more than 2 minutes then it stops the advc 100 is hooked up to jvc super vhs vcr some of my tapes that i am transfering is not good quality video . i bought the advc 100 because of the rave reviews i have been hearing and non loss of audio sync.
any and all help appreciated
thks,
ken
Are you capturing to a FAT32 formatted disk? If so, you are coming up against file size limits imposed by this disk format.
You should either be capturing to an NTFS formatted drive, or using software that will split your capture into FAT32 friendly chunks. -
Try using DVio to capture with. http://www.carr-engineering.com/dvio.htm Make sure nothing else is trying to use the disks while capturing.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 19:26 -
Canopus ADVC-100 - noisey/grainy and scaling?
By Gibson's Squares in forum Capturing and VCRReplies: 4Last Post: 2nd Jun 2011, 15:41 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
How should I capture my hi 8 videos with my Canopus ADVC 100 and TRV460
By eichelman in forum Capturing and VCRReplies: 4Last Post: 9th Dec 2009, 14:21 -
Canopus ADVC-100 outputs
By datman in forum Capturing and VCRReplies: 2Last Post: 7th May 2007, 19:24
